LOOKING FOR SNO SPORT CARB
Looking for a carb for a sno sport Thanks
sport carb
do you know the difference between sport & scoot carb ? my scoot has a carb that has a hose nipple at inlet base & the idle screw dont reach the linkage .its not same as my other scoot carb ,looks basically the same but slight differences are noticeable thought maybe it was a sport carb?
Without actually going through the parts schematics line by line, I wouldn't know the differences either. When I did view the part schematics for both machines, there were some parts that were used interchangeably (ie. needle valve assembly, float, etc) but then there were other parts that were totally different; most likely due to the engine size differences. These included the main nozzle, main and pilot jets, and even the pilot adjusting screw. Although the throttle body does appear to be the same or very close to being the same, the internal parts are definitely different.
sno sport carb
let me know i could use one. Thanks
carb
i figured out what was wrong the electric switch at bottom of idle screw is missing thats why idle screw dont work,dont know why small port at base of carb where carb fits into rubber boot @ engine is open ,seen another scoot and this port has short rubber line pointing down but open to suck air, anybody know why there is an open port behind throttle plate, wont that make it lean, does it need to be open or pluged? is it a vacume differential ? dont make sense to me. dont know wether to plug or leave open? any suggestions? thanks eddie mac
