On the side of the snoscoot carb is an electrical switch (called a carburetor switch on the microfiche). It is a small black piece with wires. Do all scoots have this? Can anyone tell me what this switch is supposed to do??
Thanks
MIke V.
Carburetor switch??
The switch on the carb is an ignition kill switch if the carb freezes up.Both of the switches have to work in unison if they dont the ignition will be killed,most scoots are disconnected but the wires from the electrical side have to be connected into each other to comnplete the circuit so the scoot will run,the carb side does not matter if it is connected into itself or not.
