75 sno twister 340 f/a backfire out exhaust pipe
i took compresoin test has 132 clutch side acd 135 mag side sled ideles fine but when you give it gas it has no power and back fires out the clutch side
It's your stator...common problem, likely the high-speed winding (blue wire). Here's a link to measure the values
http://www.hewtechelectronics.com/image ... WIRING.pdf
