Carb size and Identification 1975 340 S/T
Mike Horrigan
Post by Mike Horrigan »
What size carbs belongs on a 1975 Snotwister 340, and how do you tell what size they are?
What is the proper or best way to clean them? Is there a rebuild kit?
twisted76
Post by twisted76 »
carb is a Mikuni VM36-23. On the backside of the carb near wear it fits into the rubber boot it should be stamped 36 and under it 23
Best way to clean them is to remove all rubber parts and to soak it overnight in Lacquer Thinner then blow it out with compressed air.
There is a gasket set for the carb bowl. Needle and Seat is also readily available.
Mike Horrigan
Carb Size 340 S/T
Sled one has 34 with RS underneath.
Sled two has 36 with 42 underneath.
Once I get them cleaned will they run with these carbs?
Sled two has a Sno Stuff cdi box is there a better box?
SHewelt
Post by SHewelt »
34RS is the original 36mm carb for the 75 340...should have a #320 main jets. Yes, there is a more reliable CDI available, but no point in changing it if the CDI is still working.
Mike Horrigan
carbs cdi
Right now it will idle rough on only one cylinder, Its spits and backfires out of the other, I'm going to start with a carb rebuild, I just wanted to know what may be next. Where would I get a box if I need one?
SHewelt
Post by SHewelt »
Swap the carbs & see if the problem stays with the carb or the cyl...that will tell you if it's the spark or carburetor. If it moves to other cyl, spark is OK & carb is the problem. www.cdibox.com has CDI boxes for the MERC's with a good warranty
Mike Horrigan
Carbs rebuilt
Running on two cylinders at medium or high speed
Bogs on low speed
Will not idle without a little throttle applied
Mag side carb spitting fuel out of the overflow tubes.
How many turn should the idle and the low speed screws be set at initially?
SHewelt
Post by SHewelt »
Replace the FLOAT NEEDLE & SEAT on the carb...that is causing the overflow & rich condition...
