'76 340 T/T Idle Speed
Spottedlindy
Post by Spottedlindy »
I have got a '76 340 T/T that I purchased last spring. This is my first sled so I am new at working on them. My sled starts up easily and runs for quite a while choked but it dies as soon as I take the choke off. I can keep it running without the choke if I use the throttle. How can I set the carbs to get it to idle. Thanks for your help!
nitrofa340
Post by nitrofa340 »
The idle screws are the large screws with the heavy springs on the sides of the carbs. Start by turning them all the way in, then turning them out 3 turns and see how it idles. Turning the screws clockwise will raise/increase the idle speed, turning them out will decrease idle speed.
fastwin
Post by fastwin »
try adjusting the mixture on the oppisite side of the carbs a small brass screw also make sure the enricherers are closed.
