Chain case H E L P
hotrod
Post by hotrod »
76 TT chaincase leaking, possible cure? What do you run for fluid.
Automatic Transmission fluid only.....
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by hotrod</i>
<br />76 TT chaincase leaking, possible cure? What do you run for fluid.
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
SHewelt
Post by SHewelt »
Your lower chaincase seal is probably bad. Requires removal of the chaincase to press out/in a new one. Also check to see if chaincase gasket has failed when cover is removed. Sometimes clean it up & a little RTV will solve it during reassembly
