Offering my Twister expertise
I believe around 7000 RPM. You may spin it faster, but no point, as the torque curve falls off as RPM's increase. I've been away from the AS engine & working on the L/C's lately, so this is from memory.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by alpex3457</i>
<br />What rpm should my trail twister run at?
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
hey, my 440 TT has a cdi box on it that is not oem, so how do i know if its a prestolite system or not?, its a '76, the box is plastic and it says "snostuff' on it! help?
also, the 440 i have doesn't seem to rev as high as my 340, is that right, have no tach on the 340, and failed to read the other, what should they:) be?
It's just that, a SNOSTUFF CDI. They are imported replacements for Prestolites. All The Merc's originally had Prestolites, except the 76 Liquids. Some of the Kohlers were converted to Nippondenso systems (John-Deere & others used them), but Prestolite was the original. If you have spark & it runs, then run it!!! Some CDI's lasted forever, others failed when you shut them off, usually far from home. The 340 T/T will rev a bit higher than the 440, but not that much more. The 440 makes all kinds of power from 4000~7000RPM's...no sense reving any more as nothing good will come from it....a great FAN sled...my favorite in fact!...Scott
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by grease monkey</i>
<br />hey, my 440 TT has a cdi box on it that is not oem, so how do i know if its a prestolite system or not?, its a '76, the box is plastic and it says "snostuff' on it! help?
COMET indicates the A12 arm (45.3g) and the Purple spring. I've used the A1 arm (48.5g) and the Silver spring on my 440 T/T with great luck...very quick up to 70mph. The lighter weights may be better on the 340, as the 440 can handle the faster upshift with more mid-torque. COMET did not specify the "cc". If you know anybody with a 1977-340 Boa-Ski SS, see if they will tell you what it had from the factory in it's COMET 102C. The calibration on the Boa's was pretty good & same engine as in the Twisters....Good luck....Scott~~~~~~~~~~~~~~~~
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by MARK LAMBERT</i>
<br />SCOTT, I HAVE A 76 TT 340 WITH A COMET 102C PRIMARY CLUTCH, WHAT SHOULD I BE RUNNING FOR WEIGHTS AND WHAT COLOR SPRING THANKS FOR YOUR HELP.
