Can anyone share insite to converting the cleated 102 inch track to rubber for the ovals. If anyone has done this and ended up going with 104 inch or longer track has this affected the sleds handling particuliar in the ovals...Thanks
Image enterprises is making a rubber track conversion kit that uses a trail twister suspention and track but you will also have to change the drivers. The real bulkhead also has to be extended because of the longer track
