644 COMPLETE PISTONS
jimlaos
Post by jimlaos »
i AM LOOKING FOR Anos SET OF PISTONS FOR THE MERC 644
ironhead
Post by ironhead »
I have 2 used pistons from a 75 Hurricane II 644. Engine had about 600 miles on it. The piston from the PTO side is good. The MAg side piston lost the locating pin for one of the rings (I believe the second ring, I will have to look at the piston to be sure.) I was going to have a new pin put in at a machine shop but I stumbled on a set of new pistons instead.( Talk about luck !! ) You could also just run that piston with 2 rings instead of 3. The ring grooves will need to be cleaned up as well, but that isn`t a big deal. THe pistons are complete with pins and clips and I have NEW rings for them. If you are interested, I`ll take $100 US plus shipping from New Hampshire for the pair with new rings for both. Let me know, Guy.
