Headlight/Taillight Not Working
Post all Technical Questions and answers on Scoots and Sports here
YamaScoot
Post by YamaScoot »
Does anyone have any suggestions as to what could be causing my headlight and taillight to not work on my Sno Scoot? I've already replaced the coil/pulser and just replaced the rectifier and they still do not work. I've verified the bulbs are good and what's strange is the brake light works; just not the others. Any ideas?
Fleabagz
Re: Headlight/Taillight Not Working
Post by Fleabagz »
More often than not it, on these old machines, it is a grounding issue. Use a tester and find a good ground on the engine then see if you have power at either the head light or tail light. If not, then keep going back until you can find power. Test the hi/lo dimmer also. The fact that you have brake lights is a good sign. Should be an easy fix with a good tester.
scoot wiring.jpg (189.84 KiB) Viewed 6901 times
